Just noticed your in teesside, where abouts are you ?
What Ya Recon?
sclarke1985
, Mar 20 2012 07:04 PM
32 replies to this topic
#31
Posted 21 March 2012 - 09:03 PM
#32
Posted 21 March 2012 - 09:07 PM
only wanted a brief valuation wasnt expecting some much you shud put this on and that up
If you want a reasonably accurate valuation then you do need to provide a few photos, as things can often be seen in photos that might make a big difference to the value. Also with a classic mini the mileage, state of body work and length of MOT can make a big difference to value as well, so with all those variances it's almost impossible to put even a rough valuation on a car without a bit more detail. The ICE equipment often won't increase value significantly though, unless you specifically find a buyer looking for a decent ICE install, which to be fair isn't the highest of priorities the average classic mini buyer. If your ICE equipment is worth as much as you say, then it would probably be worth far more if you were to remove it and sell it separately..
As a ball park figure, then I'd say that a solid cosmetcialy modified 1275, in reasonable condition, with reasonable miles & a full MOT will probably fetch somewhere around the £1,800 mark at the moment. If it's nearer mint condition then more like £2.2k - £2.5k might be possible. But with the level of detail that you have given so far, your car could equally be worth more like £900, at the moment there just isn't enough detail to be able to say either way.
#33
Posted 21 March 2012 - 10:18 PM
yeah thanks i know where your coming from maybe i should post more
