Pro-Mo Kit Nr. 38
#31
Posted 17 May 2013 - 09:48 PM
#32
Posted 30 May 2013 - 03:09 PM
hello,
Today I wanted to install the sump buffle, until I discovered that thing here. I have not yet figured out where that came from. I'm a little scared. Maybe you can help me.
Regards
Chris
Posted 14 September 2013 - 04:27 PM
Hello,
found the rest of the piece in my sump. It was the slide rail from the oil pump chain. Don´t know the failure. The problem was that I had to remove the clutch again to get to the rail. But unfortunately the clutch cover will not pass the frame. So the engine had to come out again. When everything was back together, suddenly the water pump was broken. So everything down again. Since yesterday everything is back together and ready for the road.
regards
Chris
Posted 15 September 2013 - 02:31 AM
#35
Posted 18 September 2013 - 07:15 AM
Hello,
I have now installed an oil pressure gauge. Can you please tell me how high the pressure is about. For me, the pressure is about 2 bar (29psi) and acceleration at 7 bar (100psi). Is this ok?
regards
Chris
#36
Posted 18 September 2013 - 08:25 AM
Hello,
regards
Chris
Sounds like you have had fun ! had the same fun when I got mine minus engine in engine out and so on all sorted now ! well with the engine now it's diff in diff out ! and a few cross threaded holes to sort should I built it from fresh I guess
How you fit your gauge ?
Cheers James
#37
Posted 19 September 2013 - 09:02 AM
then you know just what I've been through. I hope that this was the last time the time being. The oil pressure gauge I have placed directly on the oil filter. Although it is a bit tight there, as there directly passes the chain. I had to grind a little, so that the chain does not touch the sandwich plate.
Maybe someone knows another way to tap the oil pressure ....
regards
Chris
