The block has been freshly bored to +20, it comes fitted with brand new cam bearings, new core plugs, new oil bungs, all surfaces freshly machined/cleaned up and comes painted black.
AE 21251+20 pistons are brand new and come fitted to fully reconditioned and balance A+ conrods.
The crankshaft is also brand new and comes supplied with the correct shells and thrust's to suit.
The bottom end is all built up, so that means the block has the piston's and crank all ready to go, this does NOT come with a camshaft.
The cylinder head is also freshly machined, with 21cc chambers,kent double valve springs, brand new valve stem oil seals, brand new valve guides and new inlet and exhaust valves. Size's are 35mm inlet and 29 exhaust I believe.
I'm after £600 no offers for the engine and head, I paid a lot more for it but I'd just like it gone now. I'm located near Manchester but will travel part way for the cost of fuel.
Edited by Southy, 08 April 2012 - 10:48 PM.
