Gearbox / oil leak!!!
Jordie
, May 18 2004 07:16 PM
34 replies to this topic
Posted 18 May 2004 - 07:16 PM
Its been leaking oil for months now, somets gotta be done. I dunno if its gunna be simple and i aint the technical minded guy, so if you can see wots needed from pics, i would be v.greatfull ta.
Posted 18 May 2004 - 09:47 PM
The pics are not the clearest in the world, and I'm not the most practically experienced person but I'll throw in my 2p.
If the oil seems to be leaking from the gearchange mechanism it'll be the seal where it enters the box. Most minispares places do the kit for about a fiver as its a very common problem.
If its leaking from behind the inner CV joint where it enters the differential housing that is most likely the diff output seal which is rather more of a pain to change.
Posted 18 May 2004 - 09:49 PM
ok, i need to get some one who knows what there doing to find out which 1 it is, so i can buy the part and get it fixed.
The pics where rushed as i wasnt sure how strong the mini handbrake was, while i was laid under it!
Posted 18 May 2004 - 10:01 PM
The pics are C**p, but it looks like its the gear change oil seal.
You can buy a modifed kit from Minispares that cures the problem.
Or you can go to Andrew Pages (Methley road) and buy a new atd seal. then without removing the old one fit a second seal.
Siggy
Siggy
Posted 18 May 2004 - 10:03 PM
feels stupid, lived in cas 17yrs and i dunno where Methley road is. lol, how do i replace without taking the old one off?
Will i need to remove owt?
Posted 18 May 2004 - 10:04 PM
Tip: Fix your handbrake first.The pics where rushed as i wasnt sure how strong the mini handbrake was, while i was laid under it!
Posted 18 May 2004 - 10:06 PM
lol, its fine, i just never trust cars rollin, my uncle wa crushed by one afew yrs ago.
Posted 18 May 2004 - 10:17 PM
Methley road is where the Peugeot garage is. Driving from the bus station turn right at the roundabout (Focus) then after the road turns left the Pug garage is on the right and Pages is the second (I think) on the left.
Remone the roll pin that fastens the linkage onto the gearbox. Then just tap the new one on and that will push the old one further in.
Siggy
Siggy
Posted 18 May 2004 - 10:18 PM
cheers man. I never knew that street wa methley road, any idea how much this thing will cost?
ATD seal u say, will that be right size?
I like to make sure, the amount of things i bought in my lifetime and bought wrong thing is too many to count, better safe then sorry.
Posted 18 May 2004 - 10:22 PM
That should have read STD
Just ask for a gearchange oil seal for a Mini They will know what you want.
Siggy
Siggy
Posted 18 May 2004 - 10:23 PM
ah right, thanks again! :grin:
Posted 18 May 2004 - 10:25 PM
If you are going to do it you may aswel do it properly, the hardest part on fixing the gear linkage leak is removing the pin!! took me ages to find an implement that was the exact size to knock the pin out!! Then just kept on digging at the old seal with a small screwdriver, and it slowly came out, pushed the new one in, gave it a little tap, put gear link back in, hammered pin in and bobs ya uncle!!
It really isn't a very hard job, all you need is a jack, axel stands, or some ramps, hammer, a large nail to get pin out!!! and a screwdriver. thats if it is the gear link seal gone.
Oh, and turn the makro on, on your camera, you get some much better close ups!!
Rich
Rich
Posted 18 May 2004 - 10:29 PM
ah, always wondered what that setting was too. Learning alot 2nite. I will get ramps n have another look, breeze blocks behind wheels so i can feel safe under it.
Cant harm changing it if it isnt. I just wanted to sort it, so when i change oil and filter, it wont goto waste by ending up on my garage floor.
Posted 18 May 2004 - 10:38 PM
Thats the way i felt about putting a new oil filter, and oil in it, i wasn't happy if it was going to go all over the floor!!
But if you do decide to do it yourself, i am sure me, or siggy can give you a more-in depth instructions on how to do it. It is one of the re-occuring jobs that will need doing every few years, so once you know how to do it, it is simple!!
The new seal can be bought from a car spares place, only a couple of quid and they usually have it in stock.
And yea, makro is a well handy little option!!! can get some very high quality close up pics if the lighting is right!!
Rich.
Rich.
Posted 18 May 2004 - 10:43 PM
will get some new batts for cam and see what i can get tomoz.
The car is 24yrs old and is all pretty standard, so i dunno if its either been changed lol. The curvey bit on bk of carb (with round screws) is stuck solid, so i cant fit me K&N filter, but might leave it anyway till i can get a proper RR session when its worth while (after fitting stg 1 kit for example).
I'll try get pics, dunno what i'm looking for like. can u tell me where i shud take the photo from (angle wise) so u can check if its 1 or other.
Airedale auto's can order the part in same day if needed, so thats decent enough.
