Presume it needs a full rebuild?? - its makes a noise in every gear and in neutral when the clutch is engaged (i.e. pedal up)THIS IS A FULL SET OF BALL BEARING.BAULK RINGS GASKETS AND SEALS FOR REBUILDING YOUR GEARBOX PROPERLY INCLUDING DIFFPIN AND COMPONENTS
Also think i might have a go at the engine myself. Rich has explained many a time the process (thanks :grin: ) so I won't ask again but how will i know if i need a rebore as this would require new pistons and more expence (yes?). Also when would i need my crank regrinding - how will i know if it is OK??
Oh and by the way the engine and box has done 91k...
Thanks in advance guys....
