Removing Front End
Posted 20 April 2012 - 03:18 PM
had a realy good reply last time from a green mini with black mclean bros arches on can u put them pics back plz
thanks joel,
Posted 20 April 2012 - 03:39 PM
Not sure if it's of much help however here's how i've done mine:
Chopped the wings roughly...
Then went back and tidied it up on both sides
Then cut down the inner wings at the front, and bent the metal forwards
and unbolted the leftovers.
It could be done without messing up the paintwork on the a panels and below the screen, however in a moment of "I'm 18, i know what i'm doing, i'm an adult and i can make decisions for myself" i'd plugged about four pots of filler into the gaps trying to de seam it or something...so i used the grinder to get all the crap off. Probbably a good thing i diddnt try and flipfront it at the time realy...
Posted 20 April 2012 - 04:48 PM
i think it will be very hard not do damage the paint, you'll have to drill the spot welds off the wings, where they meet the inner wings, cut around the top of the wings where it meets the scuttle, and then cut the a panel away from inside the door, if you take the door off, and grind the edge away it will come away, but if its got its original a panels on it will have two spot weld on it, you'll see where when you try pull it away, i'd just drill them out and you'd have to sort the holes out after.
that what i did with mine.
Posted 20 April 2012 - 05:05 PM
Posted 20 April 2012 - 08:42 PM
Posted 20 April 2012 - 10:51 PM
digler, do your wheels rub with those arches at all?
no, made them fit, bit close but just fine
Posted 21 April 2012 - 08:23 AM
Posted 21 April 2012 - 08:51 AM
cause im pretty low up fornt and have keep having problems with my group 6 wides rubbing, the dam inside lip is a pain
is it the lip on the wing thats rubbing? or the grp 6 arches?
if its the arches you need some wider ones,
the arches we sell are the same stlye, just wider
Posted 24 April 2012 - 03:18 PM
Posted 27 February 2018 - 10:27 PM
Has anybody managed to remove the front end without damaging the wing panels where the wing meets the scuttle? Im making a removable steel front end but replacing the wings (which are perfectly fine at the moment) will double the difficulty and time of this job.
Posted 07 March 2018 - 01:37 PM
Holy thread revival batman i was here 6 years ago!!
Yeah doable..i think...? i know the wings arnt welded to the scuttle.... at least mine were not.... maybe thats why it came apart so easy
Posted 07 March 2018 - 01:41 PM
as above.wings should not be welded to the scuttle
Posted 07 March 2018 - 06:46 PM
