Bought a facet fuel pump and regulator to replace current electric fuel pump.
Going to mount it under the floor in subframe to increase space in boot and reduce noise.
Posted 24 July 2013 - 08:08 PM
Posted 27 July 2013 - 05:27 PM
Used a reject dash to try something....
Holes need trimming up and that, but going to have it flocked and fitted to this car...
Posted 27 July 2013 - 09:54 PM
Just did the swap myself from mechanical to electric. Mounted it on a plate and mounted that to a exhaust bobbin, then I mounted that to the subframe. It's nice and quiet after start up.
Posted 28 July 2013 - 06:08 PM
Ive allready got electric, but its a round pump and the brkt is broken in the boot, so its laid againist the spare wheel and bulkhead, can be noisey at times.
Dashboard drilled and test fitted etc, sent for flocking in black.
Jordie
Posted 28 July 2013 - 06:51 PM
Posted 30 July 2013 - 07:27 PM
Dashboard back from flocking....bits turning up all over so hopefully it should start coming together over the next week.
Need to do some gauge wiring and stuff, want to tidy things up before dashboard goes in.
Jordie
Posted 31 July 2013 - 09:01 PM
Dash project....
now flocked....parts going in....
White faces and backlit dials....
Re routed some of the wires, added length to the wiring for dashboard so i can connect it up easily and fix into place. Also means dash can be removed and pulled forward should there be any reason to get behind dash.
Dash in place....not finished.....speedo dials need trim around, need green lenses for indicators etc.
Testing the electrics....
Nice semi flat surface, similar to a modern car...
Speedo lit up picture.......can be either green or blue....
Awaiting vacuum gauge + longer screws for NS speaker and it can all be fitted properly. Need to run in the vac hose and oil pressure pipe aswell once its all somewhere near to measure up.
Posted 03 August 2013 - 07:15 PM
Dashboard in and everything wired up and working....
Radio relocated under dash
Gauges working...
Posted 08 September 2013 - 07:52 PM
Posted 08 September 2013 - 07:56 PM
Dash looke awesome Jordie.
Are you using the mini through the winter ?
Posted 08 September 2013 - 08:03 PM
Posted 08 September 2013 - 08:06 PM
Posted 08 September 2013 - 08:16 PM
Posted 22 September 2013 - 03:42 PM
Had to charge battery and get it out to tweek exhaust.
But there was someone in my mini....
Posted 22 September 2013 - 05:17 PM
Just read this. Love it.
That is all
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
