Cg13 Pickup
19 replies to this topic
#16 CaptainBland08
CaptainBland08
  • 675 posts
Posted 21 August 2012 - 12:49 AM
Excellent more inspiration here :D
Just out of curiosity:
What did you do to your manifold, did you just grind out the cat and weld a pipe in or?
Also, can anyone recommend me the best steel plate and box section thickness and dimensions please as i am going to begin mine when i get back from the USA
Thanks any help appreciated
www.funkmotorsport.com
for the manifold its a standard one with the cat flange cut off, then a large 1.75 inch curve peice welded on to make the rest... i actually stole the peice of extra downpipe from a rusty old ford focus backbox. ill get a good pic of it for you tommorow.
as for the frame, would go for 30mm box, with a 3mm wall. i just used what i had. and i wouldnt copy my design if im honest... ive got much better ones in my mind now its done. lol
Chris
#17 smudger068
smudger068
  • 344 posts
Posted 21 August 2012 - 01:24 AM
Chris
excellent thanks for that reply, yeh i understand what you mean, i just needed somewere to start want to get it running then probably fabricate a better frame in the near future
:D
Edited by smudger068, 21 August 2012 - 01:26 AM.
#18 CaptainBland08
CaptainBland08
  • 675 posts
Posted 22 August 2012 - 09:27 PM
for those who wanted to see manifolds...
its definatly crap. but wont be there for too long... going to make a custom stainless jobby...
the inlet was just trimmed down as far as the injectors then welded some tube on...
far right inlet needs notching and moving over then welding up again.
and the brake bias for anyone whos interested...
Moving this to a new location tommorow... where it will be finished off... its mainly so i can carry on with my vauxhall one.
Chris
#19 smudger068
smudger068
  • 344 posts
Posted 23 August 2012 - 09:42 PM
Just seen this excellent thanks for that, i might have to go with that manifold idea as a temporey aswell, and i need a bias adjuster >_<
:D
Edited by smudger068, 23 August 2012 - 09:44 PM.
#20 Artstu
Artstu
  • 837 posts
Posted 29 December 2012 - 05:51 PM
A shame all the photos have gone, I came back to see the Micra engine in BMC green, I wish I'd saved some of the photos now.
