Gearbox's
4 replies to this topic
#1 david036
david036
  • 188 posts
  • Local Club: warton
Posted 15 May 2012 - 01:37 PM
Hi all
Where's the best place or does anybody know the different gearbox ratios on a mini/metro box? I'm mostly interested in the 2nd gear ratio's and what cars they were on. Think the one i'm looking for was in a mini van!!
#2 03jkirk
03jkirk
  • 465 posts
Posted 15 May 2012 - 09:12 PM
all the gear ratios are the same on mini and metros the only differance is the final drive ratios and these are inter-changeable and if you wana see the ratios fully guess works has a section where you can see the rpm agasint speed on graph for all gears at any final drive ratio http://www.guess-wor.../Tech/ratio.htm
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 May 2012 - 10:02 PM
Unless of course you get the Special Tuning close ratio gears.
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 15 May 2012 - 10:58 PM
The Metro HLE was a wide ratio gearbox with a first gear ratio of 4:1 Identified with a double identification notch on the gears
#5 Boycie
Boycie
  • 1,978 posts
Posted 16 May 2012 - 06:48 AM
Yes, as above, the City 'E' has a similar 'box to the Metro HLE, with a different first gear.. although I could never 'feel' much of a difference in the real world ! I've got the official dealer memo on the City E gearbox somewhere.
