Posted 16 May 2012 - 10:32 AM
There is no need to either split (and incidentally risk ruining if you do it as described above) the inner joint in two or remove the hub nut to replace this gaiter. Leave the driveshaft in, leave the hub assembled. Remove the remains of the old gaiter. Remove the caliper and split the three ball joints. Knock the whole hub off the end of the driveshaft, be prepared for its weight (tie it to the top arm with cord if you like before knocking it off). Hold the driveshaft tightly while doing this so you don't accidentally pull it from the transmission and drain the oil! Now you can replace the gaiter easily. Over-greasing CV joints is not a good idea and can easily lead to the gaiter simply splitting immediately again due to pressure. The joint needs a specific amount, I seem to remember it's 3cc in an outer joint but check the manual. The sachet included with the gaiter is generic and tends to have far too much in for one joint on a Mini. If you have cleaned it out well, you will need to put 3cc back in it. If you cannot get it all clean, or it hasn't actually become badly contaminated or dried out then just put in enough to top it up. It's hard to judge but certainly don't pack loads in to the joint. It gets very hot inside there, there must be room for expansion and for the hot grease to flow.
