Clutch Problems :(
14 replies to this topic
#1 Jwatts93
Jwatts93
  • 362 posts
Posted 15 May 2012 - 04:56 PM
Hello all,
When I put my foot to the floor when stationary, on the clutch pedal it still seems to want to move and the biting point is only just off of the floor so i always get a crunch going into reverse and sometimes struggle with other gears, can anyone tell me what is wrong ? Thankyou
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 15 May 2012 - 05:01 PM
Try adjusting it?
#3 OhDear
OhDear
  • 560 posts
Posted 15 May 2012 - 05:38 PM
posssibly needs bleeding air in the system/ or as above adjustment
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 15 May 2012 - 06:34 PM
wants bleeding or something is worn
#5 Jwatts93
Jwatts93
  • 362 posts
Posted 15 May 2012 - 07:07 PM
sorry if it sounds stupid but how do you adjust the clutch ? this is the first time i have messed with the clutch so am new to it, any help would be great thank you .
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 15 May 2012 - 07:13 PM
what yr is the car
#7 Jwatts93
Jwatts93
  • 362 posts
Posted 15 May 2012 - 07:18 PM
its a 1989 mini mayfair but it has a 1275 metro engine in so I'm unsure what gearbox is in the car if that makes sense as I've only had the car for about 2 months and don't know too much about it yet. hope this helps?
#8 tiger99
tiger99
  • 8,584 posts
Posted 15 May 2012 - 07:38 PM
We only need to know whether it is Verto or pre-Verto to assist with the adjustment procedure. Verto has the slave cylinder on a steel bracket, working a short bent lever, pre-Verto has the slave directly bolted to the clutch housing, and a long lever. Once you know that, a quick glance will tell you all. The Somerford diagrams below will assist if that is not clear.
http://www.somerford...age=page&id=145
http://www.somerford...age=page&id=144
Once you tell us which type it is, someone will be along to tell you how to adjust it, which should not be difficult. I think your problem is probably hydraulics, but it is always best to try the zero cost option of adjustment first, just in case that is all it needs.
#9 Jwatts93
Jwatts93
  • 362 posts
Posted 15 May 2012 - 08:22 PM
i haven't got the car available to look at right now but i believe that verto clutches came in in 1982? and i am pretty sure mine should be verto as i can't see it being pre 1982. i will try and have a look tomorrow to get a definite but for now i would say it is a verto if I'm right ? so how do i adjust this ? thankyou
#10 Jwatts93
Jwatts93
  • 362 posts
Posted 15 May 2012 - 08:24 PM
also where would the sale be on a verto clutch ?
#11 Jwatts93
Jwatts93
  • 362 posts
Posted 16 May 2012 - 04:10 PM
Actually just had a look in the engine bay and I think it may be a pre verto clutch this is what I could see :
#12 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 16 May 2012 - 04:21 PM
Yes, that's a pre verto one.
#13 Jwatts93
Jwatts93
  • 362 posts
Posted 16 May 2012 - 04:31 PM
When I'm looking at that picture to adjust the throw out and stop what do I need to do ?
#14 Jwatts93
Jwatts93
  • 362 posts
Posted 16 May 2012 - 07:34 PM
Anyone ?
#15 Jerry B
Jerry B
    Starting My Mini Up
  • 1 posts
Posted 21 May 2012 - 10:40 AM
www.7ent.com/news/3/article-easy-pre-verto-clutch-adjustment.html
Try the above link, explains it in detail with photo's!
