Starting Issue?
No replies to this topic
#1 greenclubby
greenclubby
  • 88 posts
  • Local Club: Wyre Forest mini club
Posted 15 May 2012 - 05:50 PM
Hi all just after some suggestions ive fitted a engine to my project. My 1st issue was a clogged up carb causing serious overfueling so i changed the carb, when i turned the key it started then died after a few seconds. ive had it running by keeping the revs up for about 10-15 seconds then if i let the revs drop it just sucks and dies seems like my spark is dissapeering ive checked for fuel in the carb and a spark i have both. Ive tryed changing the coil, new dizzy cap and rotor arm and a new power feed to the coil also put new connectors on the wiring now i cant get it to start whatsoever yet yesterday it started any ideas fuel setting isnt far out and neither is the timing ????????????????
