As I'm not a mechanic,is there a way to spot the difference between hs2 and hs4 carbs....ta...
Spot The Difference
ugly1
, May 16 2012 09:33 AM
3 replies to this topic
Posted 16 May 2012 - 09:33 AM
Posted 16 May 2012 - 09:37 AM
2 easy ways to spot differences. The dashpots are thin, and different shapes. HS2 has vertical mouting points, HS4 Diagonal
http://www.minispare...ty=pb&pid=37355
http://www.minispare...ty=pb&pid=35873
Posted 16 May 2012 - 10:20 AM
Simon...thank you..! After been told by so called experts that my carb is an hs2 I now know different...hs4 it is ..!!!
I came into the shop yesterday for a rebuild kit for hs2 carb but discovered that the butterfly in the kit is about 5mm smaller....I've no idea on diameter of carb...so mite be in again later...!
Posted 16 May 2012 - 02:44 PM
HS2 is 1.1/4 inch and HS4 is 1.1/2 inch
