Steering Column Removal Problem
6 replies to this topic
#1 jbj
jbj
  • 190 posts
Posted 16 May 2012 - 08:53 PM
I'm having real problems removing my steering column. I've removed the pinch bolt and the bolt attaching the column to the lower dash. However I can't get the column to lift off.
I've had 2 people pulling on it for the last hour and it's going nowhere. I've tried widening the pinch collar with a chisel but don't seem to he getting anywhere.
Any ideas where I'm going wrong?
#2 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 16 May 2012 - 08:55 PM
Sounds like it want's to stay in haha
#3 100ev8
100ev8
  • 622 posts
Posted 16 May 2012 - 09:23 PM
tap an old screwdriver in the clamp bit to give it a bit of a gap and rock the column side to side slightly while pulling
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,169 posts
  • Name: Neil
Posted 16 May 2012 - 09:31 PM
sounds like its rusted in place. Soak it in Wd40 or Gt85. Leave for a while and they strike the side of the clamp sharply with a hammer to help shock it off.
#5 jbj
jbj
  • 190 posts
Posted 16 May 2012 - 10:56 PM
I figured it was prob rusted on, I had to fix a hole quite near it so will have been getting nice and damp...
I've covered it in penetrating oil and will come back to it at the weekend (providing my back stops hurting!)
#6 jbj
jbj
  • 190 posts
Posted 24 May 2012 - 07:21 AM
Finally got it off!!!
I've been soaking it in penetrating spray daily for the last week and managed to get it free using a breaker bar to lever it off. Now onto the next annoying job!
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 May 2012 - 07:59 AM
Check the spline inside carefully. When they seize in place like this it's often because a section of the spline has worn and then the column position has shifted slightly, jamming the end of the pinion spline against the undamaged section of spline inside. You have to wiggle the column to engage the spline and then it will slide over.
