Evening all,
My car has really done one on me today, Iv had her running all day no problem at all. Just as I was about to go out tonight with my mates I noticed that the side lights and rear lights would not come on, then the indicators started playing up! The indicators give a random number of flashes then shut off. the indicator leaver has alot of play in it and I'm not sure if this is the problem. I was going to change the column over tomorrow but does anyone have any other suggestions?
Cheers Jack.
Another Electrical Fault.
MiniFTW
, May 16 2012 10:01 PM
3 replies to this topic
Posted 16 May 2012 - 10:01 PM
Posted 17 May 2012 - 12:15 AM
It'd help to know what year the car is. Have you got dash illumination? The column stalk won't effect the sidelights and isn't likely to the cause of the indicators if behaves the same indicating to both sides, and plays up with the car stationary (no bumps to jolt loose connections)
Posted 17 May 2012 - 08:04 AM
Its an 88 red hot. Iv checked for loose connections but cannot find any couls the flash unit be on its way out ?
Posted 17 May 2012 - 08:31 AM
checked the relays?
