Remove the plastic retaining washer from the lugs on the radiator collar and then it's a case of gently wiggling the sensor terminals by hand. They're fairly robust but awkward to get to with the radiator in situ. The sensor is made watertight by a surrounding rubber plug which can sieze if it's been there for a while.
Draining The Radiator...losing The Will!
jules_perox
, May 21 2012 07:42 PM
17 replies to this topic
#16
Posted 17 January 2017 - 08:03 AM
#17
Posted 17 January 2017 - 04:06 PM
I must be the only one that finds it really easy to take the bottom hose off...
It's quite easy to reach from underneath?
#18
Posted 18 January 2017 - 06:00 AM
If you have the wrists for it, then it is.
