So I was curious if anyone might know where I could find disassembly instructions for a Lucas dizzy with electronic ignition? The part number is AUU1534 2001 42662A 2588, I have a feeling there the weights may be frozen up inside. My advance isn't working properly, I am only getting about 5 degrees advance. I have already checked the vacuum valve and it holds a vacuum (and I am getting strong vacuum from the carb with no leaks). Additionally, as i turn it by hand I can hear a lot of clunking like something is striking the body of the distributor ??broken spring??weight??bent shaft?? i dont know but I would like to get in there and see if it is repairable since I am in the U.S. now and Mini parts aren't quite as easy to come by over here. Attached is a picture of the dizzy.
Edited by dcfoster83, 23 May 2012 - 12:43 AM.
