Hey guys,
I fitted my arches and wheels yesterday. Checked and measured hundreds of times, and it seems the wheels are sitting too far forward!
Iv checked the arches, and im pretty sure they are in the right place. There no way they could be moved forward at al without moving them right up on the wing and in front of the bumper.
Iv checked the tie bars, and they are straight (by eye)
Is there any way of moving them back slightly, probably talking 20mm max...?
Front Wheels Sitting Too Far Forward..?
screech
, May 23 2012 06:54 AM
5 replies to this topic
Posted 23 May 2012 - 06:54 AM
Posted 23 May 2012 - 10:38 AM
No. Adjusting them backwards would completely ruin the suspension geometry, in particular the castor angle would be so far off as to be dangerous.
Do not try to fix a bodywork problem by adjusting suspension. Your arches are in the wrong place, or your front end has been rebuilt at some time with badly shaped panels.
Posted 23 May 2012 - 03:43 PM
has your mini had new wings at some point ?
Posted 23 May 2012 - 03:46 PM
Do you not have adjustable tie bars fitted screech??
Posted 23 May 2012 - 09:11 PM
tie bars are used to correct caster angles not to move the wheel
Posted 23 May 2012 - 09:25 PM
You say new arches and wheels, what size wheels? have you changed from 10's to 12's? or 12x4.5 to 12x6 etc, some wheels require modifications to the front lip of the arch
