Rough Running And Idle After Full Service
10 replies to this topic
#1 Tinkerbelle
Tinkerbelle
  • 246 posts
  • Local Club: Tyred and Exhausted
Posted 23 May 2012 - 09:29 AM
Hello all,
I have just given my Sidewalk SPI a full service, cap, rotor arm, leads, plug, air filter etc etc and now it runs slightly roughly. The replaced item were all shot, I would say 20k miles and 7 years from last service.
It ran very smooth before even after being stood for 5 years.
I have read somewhere, that the MEMS is a bit dumb and needs to relearn idle control, is this correct or have I got some Aluminium oxide in the injector housing!
Matt
#2 RaLF020
RaLF020
  • 34 posts
Posted 23 May 2012 - 03:27 PM
Good chance one of the vac pipes from the inlet manifold to the fuel trap, MAP sensor or underside of the air filter has come off or is split at an elbow. Check them first.
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 23 May 2012 - 03:33 PM
You say you replaced the cap and rotor arm.. Is this an injection engine ? Because carb engines use a distributor, injection use a coil pack, Ecu, injectors etc
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 23 May 2012 - 03:42 PM
SPI's use a distributor, it just has no points in.
#5 Tinkerbelle
Tinkerbelle
  • 246 posts
Posted 23 May 2012 - 03:45 PM
Good idea- I will check the vacuum lines first I think. It was doing the typical vacuum leak thing of coughing when you change gear aswell.
#6 Tinkerbelle
Tinkerbelle
  • 246 posts
Posted 23 May 2012 - 03:46 PM
Yep, just about all the vacuum lines are shot and leaking. I also dislodged one when I removed the air filter.
Thanks again.
#7 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 23 May 2012 - 03:55 PM
I see, never owned a spi so wasn't sure :)
#8 RaLF020
RaLF020
  • 34 posts
Posted 23 May 2012 - 08:13 PM
Thanks again.
Glad to have helped. Only wish mine was so easily sorted. Been trying to get it to pass the emissions test. Vac pipes is 1 thing i do know are now ok.
#9 Tinkerbelle
Tinkerbelle
  • 246 posts
Posted 24 May 2012 - 08:49 AM
This is my first injected mini, I liked MOT time when I could distract the MOT tester and put the carbs down two flats and pass the test, stop around the corner afterwards and wind them up two flats again!
Matt
#10 sudharshn93
sudharshn93
    Starting My Mini Up
  • 2 posts
Posted 24 May 2012 - 01:24 PM
Just a newbie question, is the vacumm hose below the air filter box?
#11 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 25 May 2012 - 07:46 PM
It runs from the manifold under the air filter to a small plastic box about the length of a thumb, clipped on the bulkhead (thats a fuel trap) and onwards to the underside of the ecu. These are small-bore pipes.
