Ive just carried out an SPI to carb conversion on my Dads Cooper and I was wondering what needle I should put in the carb as a good starting point. Its a completly standard 1275 running a HIFF 38.
Got the mixture set up about right but still feels a little flat around 3-4k RPM when under load.
Many thanks.
blakie
Needle Choice........
blakie
, May 23 2012 04:42 PM
8 replies to this topic
Posted 23 May 2012 - 04:42 PM
Posted 23 May 2012 - 04:44 PM
What needle is in it at the moment?
I would guess an AAA or AAM sufficient
Posted 23 May 2012 - 04:47 PM
Umm im not sure. Its an A?? thats all I know. I would to look again.
blakie
blakie
Posted 26 May 2012 - 08:51 AM
The needle currently in the Hif33 is an ADS.
This seems to hold back around 60-70mph under load.
Any ideas what i sould pop in as a starting point?
blakie
blakie
Posted 26 May 2012 - 09:29 AM
As above - AAA as a starting point.
Posted 26 May 2012 - 10:23 AM
Ill get one ordered then. it does have a K&N fitted, do you think this will make a difference or would AAA still be ok?
blakie
blakie
Posted 26 May 2012 - 02:22 PM
AAA is what comes in a stage one kit for 1275 with 1.5"...so you're good
Posted 26 May 2012 - 04:10 PM
But it is only a starting point.....so you need to check plug colours after running hard.
