Some Advice On Modifying Mgb Manifold For Twin Hs4's
6 replies to this topic
#1 Klevdo2202
Klevdo2202
  • 615 posts
Posted 23 May 2012 - 05:13 PM
Hi guys
I bought a MGB Manifold from eBay after finding out that some of you modified them so you can fit them on Minis.
Can I ask how do you go by doing this? best place to cut, etc?
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 23 May 2012 - 05:37 PM
I rekon the manifold angle / carb face is set wrong for a mini installation? TBC.
#3 Klevdo2202
Klevdo2202
  • 615 posts
Posted 23 May 2012 - 05:42 PM
I saw a post by BMCeccose saying he modified a MGB manifold to fit, and yes, I know about the float angles are set wrong, I've sorted that out.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 May 2012 - 05:50 PM
That was 40+ years ago.!!!..yes, I just cut a section out of the cross tube, and joined it with a rubber pipe and two jub clips.
#5 Klevdo2202
Klevdo2202
  • 615 posts
Posted 23 May 2012 - 05:53 PM
Thanks for that =] to save taking my current carb out am I able to use the spare 998 to measure how big the manifold needs to be? or is it a different size on the 1275....if that makes any sense.
#6 03jkirk
03jkirk
  • 465 posts
Posted 23 May 2012 - 06:02 PM
inlet and exshast ports are spaced the same on 1275 and 998 so you could use the 998 head to measure from
#7 Klevdo2202
Klevdo2202
  • 615 posts
Posted 23 May 2012 - 06:05 PM
Epic, cheers! =D
