A Quick Ignition Question (Electronic Distributor)
2 replies to this topic
#1 Tripyrenees
Tripyrenees
  • 177 posts
Posted 23 May 2012 - 08:26 PM
Hello
After a year away from my mini and a collection of spare parts accumulating, i have now finally got time to work on the car...
I've had mutiple problems in the past concerning points that close over time and moisture so i have decided to swap over to an electronic distributor. My first concern is that the electronic distributor bought from minisport has not come with any wires or connectors to connect the module to the coil, should this be included ? i tried searching on the site yet the is no sign of this cable. I then went on to Minispares, with luck found it 20 pounds though :(, this brings me to my second question, the cable mentions for 1275cc , i have a 1000cc, is the electronic distributor compatible for both with out modifying and parts of it ?
#2 cal844
cal844
  • 9,715 posts
  • Local Club: TFMOC
Posted 24 May 2012 - 06:48 PM
yes it should be it wont cause any problems once fitted and timing is sorted. im saying this through experience as i have a 65D electronic dizzy on mine and its fine.
#3 Tripyrenees
Tripyrenees
  • 177 posts
Posted 24 May 2012 - 06:56 PM
Ah great - and did it make much of a difference reliability wise ?
