Engine Revving Over At 40
13 replies to this topic
#1 Mayfair_Bateson
Mayfair_Bateson
  • 59 posts
  • Local Club: Kendal Mini Club
Posted 23 May 2012 - 09:49 PM
As I'm driving along in 4th gear at around 40mph and I put my foot down the engine just revs and doesn't go any quicker, as if it wasn't in gear at all, if I put my foot down gently I get to around 50mph and it does the same, just revs over
The engine I have in is a 1098 with the standard gearbox
Any idea as to what it could be would be great!
Thanks guys, Matt
#2 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 23 May 2012 - 09:51 PM
Have you ever had the car timed up / rolling roaded? Mine used to do this until I got it rolled :proud:
#3 MINI WILL
MINI WILL
  • 559 posts
Posted 23 May 2012 - 09:55 PM
Is the clutch slipping
#4 Mayfair_Bateson
Mayfair_Bateson
  • 59 posts
Posted 23 May 2012 - 09:58 PM
It's timed up properly, no harm in checking again though I suppose
Got no clutch slipping, picks up fine it's strange can't fathom it out
#5 ludiluka
ludiluka
  • 41 posts
Posted 23 May 2012 - 10:00 PM
Propably you will need do replace the clutch i am 100% shure
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 23 May 2012 - 10:01 PM
Low engine speed high load is the worst case for clutch slip.
I'm afraid that is all it can be!!
#7 Mayfair_Bateson
Mayfair_Bateson
  • 59 posts
Posted 23 May 2012 - 10:03 PM
Tried setting off with handbrake on and the car just stalls when I let the clutch out??
#8 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 23 May 2012 - 10:07 PM
The only way the revs can increase without the car going faster in the same gear is the clutch slipping. Are you sure it's the revs increasing or just extra noise from the wider butterfly opening?
Edited by mini-luke, 23 May 2012 - 10:07 PM.
#9 HafMan
HafMan
  • 383 posts
Posted 23 May 2012 - 10:08 PM
this is happening to mine and im sure its the clutch.
Well it only happens when the clutch is used a lot.
100% slipping clutch
#10 MINI WILL
MINI WILL
  • 559 posts
Posted 23 May 2012 - 10:11 PM
Find a steep hill drive up it and when you are driving up accelerate hard if the engine rpm increases and you dont move you know its the clutch.
Edited by MINI WILL, 23 May 2012 - 10:12 PM.
#11 Mayfair_Bateson
Mayfair_Bateson
  • 59 posts
Posted 24 May 2012 - 01:17 PM
So we thinking the clutch is gone then?
#12 HafMan
HafMan
  • 383 posts
Posted 24 May 2012 - 02:35 PM
on its way out, is what i'd say.
#13 tiger99
tiger99
  • 8,584 posts
Posted 24 May 2012 - 03:52 PM
Yes, can only be the clutch, and it will get worse. Best to change it now, before you end up needing a new flywheel.
#14 Mayfair_Bateson
Mayfair_Bateson
  • 59 posts
Posted 24 May 2012 - 05:00 PM
Thanks for the replies people much appreciated! Let the clutch changing begin
