You're so dirty minded.
I'm fitting my switch panel with not much luck. I've lost one of the nuts for the standard switch panel brackets, anyone know what nut size to use? I've got about 50 small nuts but none of them bloody fit *typical*.
10 Points If You Tell Me The Size Of Your Nuts
iDemonix
, May 24 2012 11:30 AM
8 replies to this topic
Posted 24 May 2012 - 11:30 AM
Posted 24 May 2012 - 11:37 AM
Depends how cold it is... Today they're hanging like a very sweaty monkey!
Posted 24 May 2012 - 11:39 AM
LMAODepends how cold it is... Today they're hanging like a very sweaty monkey!
Posted 24 May 2012 - 11:43 AM
-10unf
M5 might go on?
M5 might go on?
Posted 24 May 2012 - 12:29 PM
yeah as above its going to be a UNF size,, Unified FINE, if you have taps it is possible to retap BSP (i think) which are about 2 TPI different i know my dad tapped out a load for me the other week!
minispares sell UNF pretty cheap aswell, the metric ones will be very close to fitting on but after about a thread go tight?
Posted 24 May 2012 - 12:50 PM
M5 is within an 'nth of the pitch and a tad bigger diameter. 3/16bsf is the same pitch, but it'll be tighter because it's 55 degrees tthread angle (metric & unf are 60). You stand a better chance of finding an M5 nut, but you may as well get the correct one if you buy online.
Posted 24 May 2012 - 01:25 PM
I think I have some M5, but as people have said, after a turn they go stupidly tight.
So M5 is the almost fit from a metric. What is the size/name of the bolt in Imperial? I'll nip to a machine mart or hardware store after work.
Posted 24 May 2012 - 01:37 PM
10unf
Posted 24 May 2012 - 01:50 PM
yeah ethel it is easy to retap i think it must have been BSF that my dad used, as there are only 2 tpi difference the tap will recut it to fit... obviosuly its easier to buy the correct one in the first place though
