Changing Oil Pick Up Pipe?
4 replies to this topic
#1 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 24 May 2012 - 11:18 PM
Is this possible without stripping the box?
#2 Ethel
  • 26,585 posts
Posted 25 May 2012 - 12:09 AM
You have to lift the layshaft, not too difficult.
#3 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 25 May 2012 - 05:53 AM
Just awkward as a job due to the thrust washers
#4 Cooperman
  • 23,513 posts
Posted 25 May 2012 - 05:05 PM
With the gearbox on the bench it takes about 40 minutes.
As said, you need to remove the layshaft to get the old pipe out and to loosly fit the new one. Then refit the layshaft, bolt up the new pick-up and it's done.
It's a good opportunity to fit a new layshaft and needle roller bearings if necessary.
#5 SAL 821X
SAL 821X
  • 1,890 posts
Posted 29 May 2012 - 09:49 AM
Thread bump.....
I removed the original oil pipe from the gearbox but the centre oil pipe doesn't seem to look like it will fit as there is some of the casing in the way.
Is this normal?
