I'm on a budget >.<
Rather than buy a new hazard switch, could someone tell me which colour pins do what (or which wires do what on the connector) so that I can use a continuity tester to test the switch OR just use a piece of wire to bridge a connection.
If so that would save me spending £15 on a new switch and waiting a few days for it to turn up.
Electrics Overhaul - Hazard Switch Testing
iDemonix
, May 25 2012 09:01 AM
4 replies to this topic
Posted 25 May 2012 - 09:01 AM
Posted 25 May 2012 - 09:13 AM
Bottom 2 pins connect when it's off, top 4 all connect each other (& disconnect the bottom 2) for on.
Posted 25 May 2012 - 09:14 AM
So if I bridge the bottom 2 sockets, the indi's should work.
If I bridge all 4 top ones together with a piece of metal, hazards should flash.
Right?
Right?
Posted 25 May 2012 - 09:17 AM
Yes, don't forget you need the ignition on for indicators.
Indicators: the 2 light green wires
Hazards:
light green / pink - from haz flasher
green / white - right lights
green / red - left lights
green / light green - tell tale (loops back to the switch's illum, little spade on the side)
Hazards:
Posted 25 May 2012 - 09:26 AM
Thanks Ethel, superb, just what I needed.
