Fan Belt Squeal When Engine Warm
5 replies to this topic
#1 SimonWicklow
SimonWicklow
  • 153 posts
Posted 25 May 2012 - 10:08 AM
at first start up there is no noise from the fan belt but after the engine gets up to temp it starts to squeal, the belt is as tight as it will go and the alternator was replaced around 3 months ago. I found out i've got a leak coming from my thermostat housing, could it be something to do with this?
It's a 94 cooper spi if that makes any difference
#2 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 25 May 2012 - 10:11 AM
Well seeing as the thermostat housing is directly above it, and it's leaking, I wouldn't rule it out.
Have you checked to see if the belt gets wet at all?
#3 tom1234177
tom1234177
  • 369 posts
  • Local Club: TMF & BMC
Posted 25 May 2012 - 10:14 AM
The leak needs sorting anyway, so you might aswell start with that, could well be the cause, as when the engine warms up the thermostat opens so there's going to be water/coolant running through it
#4 SimonWicklow
SimonWicklow
  • 153 posts
Posted 25 May 2012 - 11:00 AM
Just had a look, the top pullet was soaking wet round the back of it and dripping down onto the bottom, im guessing its leaking from the back of the thermostat and dripping down. Shall i just replace the gaskets or just do the whole housing?
#5 tom1234177
tom1234177
  • 369 posts
Posted 25 May 2012 - 01:56 PM
Just the gasket, can't imagine the housing itself failing.
#6 Spitz
Spitz
  • 1,716 posts
Posted 25 May 2012 - 04:32 PM
Plus....check the belt. It might not be the correct "V"
I have an an instance of squeeling belt ( tight )....turns out the correct size was used but not the correct profile
( don't over tighten your housing....only about 10lb's needed as I recall )
