Rear Suspension Question
#16
Posted 27 May 2012 - 01:39 PM
I'd hate to have the arches moved, they're riveted in place and would be a nightmare to move, but as I said, even if the arches are a problem, the rear is still too low regardless and needs raising.
#17
Posted 27 May 2012 - 02:28 PM
Edited by bmcecosse, 27 May 2012 - 02:28 PM.
#18
Posted 27 May 2012 - 03:32 PM
#19
Posted 27 May 2012 - 03:48 PM
#20
Posted 27 May 2012 - 05:38 PM
Can someone tell me if buying the following would give me an overhaul and will all fit together:
Hi-Lo's
http://www.ebay.co.u...#ht_1887wt_1161
Damper's
http://www.ebay.co.u...9#ht_1101wt_986
Rubber cones/doughnuts (I can collect these as it's 5 miles away)
http://www.ebay.co.u...74#ht_500wt_986
Knuckle's
http://www.ebay.co.u...e#ht_1035wt_986
Knuckle cup's
http://www.ebay.co.u...50#ht_500wt_986
Would come to about £205, not too bad I think?
Edited by iDemonix, 27 May 2012 - 05:40 PM.
#21
Posted 27 May 2012 - 05:55 PM
You'll have to remove the fuel tank to get at the N/S top shock mount. When you do it'd be wroth cutting a hole in your seat back so that in the future you only need to remove the rear seat to get to the top of the shock.
Edited by Tupers, 27 May 2012 - 05:55 PM.
#22
Posted 27 May 2012 - 07:15 PM
Ok, no cups, even better.
I'm going to order all of that stuff tonight and hopefully have a bash at fitting it this week, probably the biggest job I've ever done on a car!
#23
Posted 27 May 2012 - 08:29 PM
#24
Posted 27 May 2012 - 10:33 PM
#25
Posted 27 May 2012 - 10:39 PM
#26
Posted 27 May 2012 - 10:49 PM
Well I know you're against hi-lo's but if I'm doing every other part then I'll just do the hi-lo's too for the sake of it. I know you say I'd never change the height but it'd be nice for when I do road trips with my mates, 4 lads equipped with luggage is going to put some strain on the old springs! And as said the arches aren't perfect, so be nice to just jack it up, raise it and drop the car back down.
I'm not going to by a kit for front/back as you only save a few £, so I'll just wait until the time comes for a new subframe and the engine swap.
I appreciate everyones input, I'm now going to buy everything I listed above, except the cups.
Penultimate question: Should I lather everything in grease? I'm assuming I can just pack the cups with standard grease, is it worth greasing any part of the cones, and if so, assuming I should use red rubber grease?
Last question: Should the shocks I link just slide straight on or do I need some form of bushings?
#27
Posted 27 May 2012 - 11:06 PM
#28
Posted 28 May 2012 - 11:34 AM
