Cooper Gear Linkage
27 replies to this topic
#16 MiniLuke
MiniLuke
  • 1,205 posts
Posted 26 May 2012 - 09:00 PM
No, just checked some diagrams of the casing, it's not a bracket, sorry. Hacksaw it is then!
#17 BennMurray
BennMurray
  • 30 posts
Posted 26 May 2012 - 09:57 PM
yeah looks like it! Just really awkward to get to, thanks for the reply!
im suprised that no1 else has had the same problem
Edited by BennMurray, 26 May 2012 - 11:35 PM.
#18 jamesmpi
jamesmpi
  • 1,940 posts
Posted 27 May 2012 - 09:22 AM
Have you looked here to see if there is a description on how to separate them?
http://mini.nicehelp...Shop Maunal.pdf
I remember that I had to drive a small pin out with a hammer and punch to get my gear linkage apart
#19 MiniLuke
MiniLuke
  • 1,205 posts
Posted 27 May 2012 - 11:16 AM
http://mini.nicehelp.co.uk/Work%20Shop%20Maunal.pdf
He's already got the roll pin out by the looks of it.
#20 BennMurray
BennMurray
  • 30 posts
Posted 31 May 2012 - 07:22 PM
yeah ive got the pin out, its the other linkage i cant get off! Still having no luck, anyone else got any ideas??
#21 R1minimagic
R1minimagic
  • 4,660 posts
Posted 31 May 2012 - 07:29 PM
Just punch and drill both ends and it will come off, simple!
#22 BennMurray
BennMurray
  • 30 posts
Posted 31 May 2012 - 07:47 PM
theres no room for a punch never mind a drill!
#23 MiniLuke
MiniLuke
  • 1,205 posts
Posted 31 May 2012 - 07:56 PM
Right, got me thinking this. Are you removing the engine? If so can you undo the other end of the rod? If you can remove the linkage and selector leaving only the rod, when the engine is lifted it will swing down and not be in the way. Once out should be easy to remove.
#24 nev_payne
nev_payne
  • 2,249 posts
Posted 31 May 2012 - 07:59 PM
Proper tool for a proper job... there's room down there.
#25 BennMurray
BennMurray
  • 30 posts
Posted 31 May 2012 - 08:28 PM
Yeh i think thats what I'm going to do, gonna have to raise the mini up a little bit more to allow for the length of the selector to come out
#26 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 01 June 2012 - 12:42 AM
The other end of the rod can be undone. It is secured with one nut.
#27 BusheyTrader
BusheyTrader
  • 484 posts
  • Local Club: Nope
Posted 01 June 2012 - 02:54 PM
I had the same problem and used lots of WD40 but a tad too much brute force. The end of the rod is a touch distorted...
#28 BennMurray
BennMurray
  • 30 posts
Posted 01 June 2012 - 06:17 PM
thanks for the photos and advice, very much appreciated!!
