Whistle While You Rev
Posted 26 May 2012 - 10:53 PM
It's definitely not a squeal but a whistle and only presented over a small rpm range (about 70% throttle), any more or less and it would stop.
It wasn't obtrusive, just odd and I hate random noises.
Anyone else encountered this or similar?
Posted 26 May 2012 - 10:57 PM
Posted 26 May 2012 - 11:05 PM
I guessed it was carb ended, suspected something chokey. K&N sounds good though as long as nothing is 'up'
Posted 26 May 2012 - 11:34 PM
I wouldn't go around blissfully unaware. The air filter shouldn't make noises, get it checked out properlyOh right, that would make sense that it only started the time I went for a long higher speed drive, without the stereo blasting due to a passenger, that I notice it, right after fitting a K&N cone!
Posted 27 May 2012 - 12:14 AM
Checking out curious noises is of course best practice, hence first port of call being here to find out similar cases.
Posted 27 May 2012 - 12:54 AM
I really don't think anything is abnormal, unless you have an air leak.
Posted 27 May 2012 - 08:05 AM
Posted 27 May 2012 - 08:48 AM
Posted 27 May 2012 - 10:29 AM
It only manifest after changing the filter, it's been on a week or so but last night was the only time I've driven at motorway speeds without the stereo up as there was a passenger.
It would seem a fair bet that I'm hitting that 'not so sweet' spot and hearing the whistle. But yeah 5mins to swap the filters and blast up the A13 wil confirm :)
Posted 19 June 2012 - 07:30 PM
Posted 19 June 2012 - 07:33 PM
General concensous is that it's just resonance, I've had nothing go bang, pop, or shudder since fitting it and the noise starting. It also went away when I put the normal filter and box back on.
Enjoy the whistle of more induction :)
Posted 19 June 2012 - 09:45 PM
