Steering Adjustment?
5 replies to this topic
#1 Macast
Macast
  • 23 posts
Posted 01 June 2012 - 02:22 PM
I'm going to be moving my seat further backwards so it's more comfortable for my feet but can you also bring the steering wheel closer to you or not? Is it possible on a Mini?
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 01 June 2012 - 02:26 PM
Not with the standard column, as such. You can get a lowering bracket that does bring the wheel closer as the column moves down in an arc.
#3 JustSteve
JustSteve
  • 1,624 posts
Posted 01 June 2012 - 02:40 PM
You can get drop brackets to lower it, then use a dished steering wheel to bring it closer.
I have 3 wheels of different dishes :P
#4 racingbob
racingbob
  • 1,643 posts
Posted 01 June 2012 - 03:30 PM
yes i bought drop bracket and more dished wheel
and its nice to drive now as being tall and slim
with seat back had to make some extended brackets
now knees dont touch steering wheel
#5 tiger99
tiger99
  • 3,892 posts
Posted 01 June 2012 - 07:21 PM
Be very careful with drop brackets. They have been implicated in a number of total steering failures, some fatal. It was not always because the person fitting them failed to loosed the rack U bolts to allow the pinion to line up with the column. If the bracket is not sufficiently stiff, or accurately made, a sideways positional error will also cause spline wear and subsequent failure.
In the 1960s, BMC as they then were issued a very serious warning about using drop brackets, after some people had been killed, and the design of the Mini was wrongly being blamed.
I would NEVER drive a Mini with a drop bracket fitted.
#6 bmcecosse
bmcecosse
  • 9,575 posts
Posted 01 June 2012 - 10:32 PM
Exactly ! 2nd for that !! The BMC design is such that the wheel will move forwards away from the driver in a heavy frontal crash. With the stupid drop bracket fitted - it will spear straight back at you. Don't do it!
Mini Spares
