Spi Electrical Issue
4 replies to this topic
#1 Darynski
Darynski
    Starting My Mini Up
  • 3 posts
Posted 07 June 2012 - 03:36 PM
my 1996 spi doesnt start due to it not sparking. it has a new battery, HT leads, plugs, distributor cap and ignition coil. not sure whether its a bad earth (as im not sure where to locate them) or if ive fried the ecu? any help would be great. cheers
#2 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 07 June 2012 - 04:19 PM
If it wa ok it before it must be either a faulty part or incorrect fitting of the new parts,try substituting the old ones starting withe the coil.
#3 Darynski
Darynski
    Starting My Mini Up
  • 3 posts
Posted 08 June 2012 - 01:58 PM
it had a very weak spark before and wouldnt start as a result (hence the changes). all parts are fitted correctly according to the haynes manual but it doesnt show where the earth connections are. if someone could point me in the right direction as electrics arent my strong point it would be appriciated.
#4 Miniholic
Miniholic
  • 132 posts
  • Local Club: MCR Yorkshire
Posted 08 June 2012 - 07:04 PM
The earth point for the wiring loom is on the crossmember behind the ECU, just below the triangular strengthener. What condition is your engine earth strap in? It will probably be fixed to the top engine steady?
#5 Darynski
Darynski
    Starting My Mini Up
  • 3 posts
Posted 09 June 2012 - 03:24 PM
Thanks man, it started first time after cleaning the points :)
