The person who had the car before me put loads of mk1 pieces on the car for some reason (swing plate, grille etc.) And I want to change it all back or upgrade. The car is a 89 flame and I realy want a red grille without the moustaches that I dont like can anyone help me find one? Also, I know this is styling but would anyine be interested in some mk1 parts?
Cheers Joel
Coloured Grilles
jmmini
, Jun 28 2012 12:35 PM
6 replies to this topic
Posted 28 June 2012 - 12:35 PM
Posted 28 June 2012 - 01:14 PM
We make the later coloured grilles if thats what you are after? www.minispares.com/ala6668red.aspx
Posted 28 June 2012 - 01:37 PM
Cheers, would this fit on my car then?
Posted 28 June 2012 - 01:46 PM
The later style grills had a piece of trim attached to the bonnet, the lip that these mount to will have probably been cut off to allow the use of the earlier grill. Other than that it should be an easy swap.
With trim: http://is03.thegumtr...g/136533487.jpg
Without lip: http://www.mcdonald-...ides/front1.jpg
Posted 28 June 2012 - 01:57 PM
http://item.mobilewe...nid=93550546319
Like this? It would look good with red grille. How would I fit this?
Posted 29 June 2012 - 09:36 AM
This is spot welded onto the bonnet edge, if yours had a Mk1 grille, those would have been drilled out with varying levels of care to remove the lip.
I managed to use self tappers to re-mount a new lip onto my bonnet where it had been removed by previous owner. I did not even both to paint it, as it does not get seen, but if welding it, probably a good idea to re-paint whole bonnet.
Posted 29 June 2012 - 10:33 PM
Well I've got black bonnet stripes so a black one wouldnt need painting. The drilled holes ate neat so could I bolt it in somehow?
