Bottom Ball Joint Tight With Spring
4 replies to this topic
#1 rawky
rawky
  • 419 posts
Posted 01 July 2012 - 02:08 PM
Hi there,
I am doing my ball joints at the moment; lapped them, shimmed them with no spring until they span easily with my fingers and didn't snag at all, and then fitted the spring.
With the spring however, I can't spin it by hand and it takes more force to move it. Is it ok? Dont want my wheel to fall off!
#2 Yoda
Yoda
  • 1,958 posts
Posted 01 July 2012 - 02:12 PM
If it was OK without the spring, then you are good to go! Just keep them regularly greased, something a lot of people forget to do these days.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 01 July 2012 - 03:59 PM
If it 'spins easily' without the spring - that's TOO LOOSE !! It should 'just' be able to be moved about with a ring key hooked over the shaft - without the spring....... The spring is basically just an anti-rattle device.
#4 rawky
rawky
  • 419 posts
Posted 01 July 2012 - 04:14 PM
I just can't believe that something like that would be engineered so that you had to make it so tight that it only moves with a spanner.
There is no play in the thing at all, and I don't see why it needs to be so very tight!
#5 rawky
rawky
  • 419 posts
Posted 02 July 2012 - 05:30 PM
Fitted the hub for a test today and there is no play at all so I am struggling to understand your advice? Regardless I will carry on!
