Rebuilt Turbo Short Engine, Turbos, Other Turbo Goodies. Pictures Now Added
36 replies to this topic
#1 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 03 July 2012 - 11:43 AM
Ok so regretfully i am deciding to sell up all my a series engine bits and pieces. I will be going to himlwy show this sunday 8th so can bring along parts if needed. otherwise collection is to be from blackpool or contact me for postage costs. Ok for sale is the following which excludes postage costs.
Complete megajolt set up (excl wiring loom and brackets) £200 *SOLD*
T3 turbo with exhaust manifold £120 *SOLD*
Turbo carb £90 *SOLD*
Modified plenum chamber with dump valve £50 *SOLD*
Inlet manifold £30 *SOLD*
Minispares rocker cover with new seals, t-bars £45
Rebuilt linered 1275 block with turbo pistons, new rings, new hone, new thrust washers, new con rod bearings, new big end bearings. Centre main strap (cap not machined), mg metro cam. The crank has been reground. The deck does have some surface rust. All that is needed is cam bearings. Also comes with new timing chain back plate and used timing cover. £350 *PRICE DROP TO £300*
Td5 intercoler with hoses £80
Td04 turbo £80 *PROV SOLD*
Standard gearbox with x-pin diff £100 *SOLD*
Standard flywheel with turbo clutch £40
K&n air filter with hose £15
Im pretty sure i have more items which i will include when i realise what ive missed.
I will get pictures uploaded soon.
Edited by metrovan88, 10 August 2012 - 03:22 PM.
#2 Lucas1988
Lucas1988
  • 415 posts
  • Local Club: Frome Mini Club
Posted 04 July 2012 - 06:14 PM
i dont suppose you have the timing chain for sale?
#3 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 04 July 2012 - 07:25 PM
No i dont sorry
#4 tom130691
tom130691
  • 147 posts
Posted 05 July 2012 - 01:15 AM
where are you and lowest price on the gear box?
#5 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 05 July 2012 - 09:07 AM
im in blackpool.
#6 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 05 July 2012 - 09:17 PM
Autogage smoked with back light 30 psi boost gauge with pod, hose and wiring
has a scratch on the display and is dented on surrond. £15
Tims 2 bar boost gauge brand new never used with all fittings £20
Timing cover back plate brand new never used £10
Tims vaccum gauge (gauge only) £8
water pump in good condition (just needs a clean) £10
Clutch Housing Breather £
Dump Valve £8
Gasket lot £8
Genuine SU carb Oil never used £5
Oil filter pick up £8
Distributor cap with leads £8
small breather £3
Alternator good condition needs a clean £15
Edited by metrovan88, 10 August 2012 - 03:44 PM.
#7 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 05 July 2012 - 09:18 PM
Megajolt setup now sold
#8 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 05 July 2012 - 11:52 PM
Have you got everything needed for a turbo? Ie if I just wanted the turbo gear to convert my mini to turbo and how much? Won.t be needing the turbo or mani tho as I'll try and find a t2 manu and turbo so I dnt need to fit a box.
#9 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 06 July 2012 - 09:16 AM
well you need to consider what type of boost and bhp you want. when youve decided that you will need to consider compression ratio. the block is perfect for a turbo engine as it has 12cc turbo pistons. you will need a decent head with large chambers to reduce comp ratio if you want alot of boost. you will need other bits and pieces. but i have the majority of parts as listed. if you want anything pm me what you want.
#10 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 06 July 2012 - 02:00 PM
Not looking at much boost, just want to do something fun to my gt while I'm building my k1100 engine. Not looking for massive gains it's more for the fun of turboing a car as I've never owned a turbo'd motor. If I could do it for a few hundred pound then I'd do it but if not my gt is pretty quick.
#11 daviedevil
daviedevil
  • 200 posts
  • Local Club: BD developments
Posted 06 July 2012 - 02:19 PM
How come everything down the road from turns up when I'm skint. Good luck selling your turbo bits
#12 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 06 July 2012 - 05:52 PM
Well the t2 option is expensive with the 300 mirage manifold. When building engines consider this
Performance
Reliability
Cost
You can only pick two.
Daviedevil that would be convinient if you was to buy some turbo gear :)
#13 daviedevil
daviedevil
  • 200 posts
Posted 06 July 2012 - 06:04 PM
shame i'm skint, strugglng to sell a scissor lift ramp at the min that i thought would go in no time.
I'm gagging to get the van turbo'd
#14 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 06 July 2012 - 06:26 PM
It's cool I've got two daily drivers so reliability isn't a problem haha, I'm thinking about selling my k1100 stuff or just putting it away in storage and just build a semi decent a series with a turbo or supercharger. I've got a freshly bored 1330 with low comp pistons but they're just your bog standard pistons it's just trying to decide what to do as the money I'd put aside for the mini has dwindled very quickly and now have about 1500 to spend over two minis. Like I said don't need loads of power just aslong as it's fun.
#15 metrovan88
metrovan88
    Starting My Mini Up
  • 4 posts
Posted 06 July 2012 - 06:38 PM
1500 iant alot for two minis really. Well you should get a list together of what you want. Turbos are alot of fun
