Some Cylinder Head Questions...
5 replies to this topic
#1 chipmongrel360
chipmongrel360
  • 103 posts
Posted 03 July 2012 - 10:09 PM
hi, i'm planning a 998 engine build and i've found a guy on gumtree selling a couple of 1275 heads just down the road from me :D
i have a few questions for you guys
1 - the guy is asking for £90 for a ported 1275 head, is this a fair price?
i've asked him for close-up pictures of the porting work done to it so i can get your opinions on how good the porting is.
2 - he also has what he describes as a big valve race 1275 head. would this work on a 998, with an uprated cam and the like? and if it did work, would the benefits be much greater than the ported 1275?
cheers, Chris :)
#2 Ethel
  • 26,586 posts
Posted 03 July 2012 - 11:53 PM
12g295 (998 Cooper) would be my preference but a near standard 12g940 (1275) can work well. If you're going to increase the valve lift with a cam you will need to think about pocketing the block.
#3 chipmongrel360
chipmongrel360
  • 103 posts
Posted 04 July 2012 - 04:26 PM
from what I've read the 12g295 head and the 12g940 head provide similar results on a 998 if set up correctly, though I could be wrong? I think i've settled on using a 12g940 head anyway, simply because it'll be easier to find.
#4 lewistranter
lewistranter
  • 61 posts
  • Local Club: Central Miniis
Posted 10 July 2012 - 02:06 AM
Personally it would be the 12g295 as I've just bought one:) but they sell for stupid money on eBay!
Obviously if you get the 940 then fair enough, either way theyre both much better than standard 998 heads!
#5 Cooperman
  • 23,513 posts
Posted 10 July 2012 - 07:44 PM
With a 12G940 head onto a 998 block you'll need to do some careful measuring, especially if you want to fit a higher-lift cam. The valves may clear the block, may need to be recessed deeper into the combustion chambers or the block may need stripping and pocketing.
With a 295 head the compression ratio needs to be measured and the head skimmed to get it right.
#6 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 10 July 2012 - 09:04 PM
You'll also need to measure the chambers in the 940 head if you decide to use it. Fitting one will raise your compression considerably, even if it's standard & more so if it's been skimmed.
