Anyone Got A Supercharger Or Turbo Fitted To Thier Mini?
Posted 06 July 2012 - 08:52 PM
Posted 06 July 2012 - 08:59 PM
Nah they're a load of rubbish, walk away with your nose in the airare they anygood, what's your story?
Posted 06 July 2012 - 09:01 PM
Posted 06 July 2012 - 09:33 PM
Posted 06 July 2012 - 09:45 PM
Posted 07 July 2012 - 01:43 AM
depends on the engine build
built right they can be just as reliable
and hey if you dont like power then i guess its not for you :)
you can only have two of the below
POWER
RELIABILITY
CHEAP
Posted 07 July 2012 - 07:00 AM
Posted 07 July 2012 - 07:42 AM
Posted 07 July 2012 - 07:56 AM
Im waiting on specs of it as its a direct replacement for the eaton.
what i have herd from someone in America using it is there running 18 psi on it.......
Im waiting to hear a price on it because if its affordable Im going to use it on my Slark blow through set up
Posted 07 July 2012 - 08:54 AM
Anyone else that says turbos and normal superchargers are wrong, they all rin the electric ones and just dont want you to have the power they have! Get an electric one off of ebay!!! Added 50bhp to my mini goes like **** on a shovel mate!!!
Edit: Dont listen to that james guy above, he likes boys and sells camels
Edited by CraigieB, 07 July 2012 - 08:55 AM.
Posted 07 July 2012 - 09:19 AM
Posted 07 July 2012 - 11:49 AM
To make power an engine needs to suck in enough air to burn the fuel in. There are a few options to increase air consumption:
1.Improve breathing efficiency
2.Bigger engine capacity
3.Spin it faster
4.Cram it in with some form of compressor
1. Is a win/win option as it will pay off with the other three, also improves economy, and is the cheapest & easiest.
2. Starts to get expensive as you need new pistons & a rebore as a minimum, and you can only make it so much bigger before you run out of metal to cut away.
3. Is a similar story, making the bottom end survive high rpm gets expensive, and raising the rpm where the engine makes best power adds another issue in the gearing requirements. Both 2 & 3 are restricted by how successful you are with 1.
4. Avoids all those limitations to a reasonable degree, but can be at least as expensive. The A Series isn't the best breather so it responds well to blowing.
Posted 07 July 2012 - 06:11 PM
