Quick Rack Steering For Sportspack?
Posted 18 July 2012 - 10:29 PM
When looking at Minispares' it might look like sportspack Minis had an own steeringrack with less lock to prevent the wheels from rubbing the arces. Is there not a way to adjust this? Or is there a modification to be done to the steeringrack to solve this? I have 7 in deep dish rims and they are already rubbing slightly.
Posted 18 July 2012 - 10:31 PM
Posted 18 July 2012 - 11:33 PM
I am very curious if there is a simple way to set the correct steering lock to the quick rack so it will fit my Sportspack-Mini.
Posted 19 July 2012 - 01:09 AM
Posted 19 July 2012 - 01:56 AM
The limited travel rack for Sportspacks doesn't affect the ratio. It just limits how far the wheels can be turned. Sportspacks have a larger turning circle because the rack limits how far the wheels can be pivoted. That was always a drawback to me, as the Sportspacks didn't have the parking-lot manuverability you'd think a Mini-sized car should have.
Edited by bluedragon, 19 July 2012 - 02:00 AM.
Posted 19 July 2012 - 07:41 AM
Posted 19 July 2012 - 11:59 AM
Posted 19 July 2012 - 12:05 PM
Posted 19 July 2012 - 02:08 PM
The quick rack is 2,2 turns from lock to lock as opposed to 2,7 for standard. So it is 23 % faster and should also be 23 % heavier i suppose? I can no doubt live with that. I belive servosteering is for whimps, and think a real man should have muscles to steer his car. If i fit semi-slicks to the car, i will agree I might be challenged...A quick rack with wide 13" wheels and tires may prove to be a real chore to muscle around at low speed. The quick rack, of course, trades leverage for shortened motion. So the rack will require more effort to turn. Maybe not so bad with a 10" 145/70 tire, but considerably more of a chore with a 13" 175/50. Unless I had a chance to try it out myself beforehand, I'd avoid it for a street driven Mini.
I have seen many people praise the 10" wheels. I have been qurious as to why people say that as they must have a much taller tirewall and therefor it will flex more than the 175/50-13 consequently giving a less sharp steering.Now I am well aware that there is more to handling,roadholding and steeringfeel than the hight of the tirewall and I suppose the tires also have a smaller diameter giving a lower CG and a different roll centre. I belive it would look quite silly under the big arches, and also the 10" won't fit over the brakes. So it will be quite expensive with new rims, new tires, new (inferior?) brakes and probarbly a unsatisfactory look.If you want to sharpen up the handling try fitting 10" wheels
Thanks for that information. Is it this http://www.somerford...oducts_id=15054 you are refering to?If you want to reduce the steering movement for 13" wheels KAD do a set of bushes that attach to the steering arms under the boot. I just bought some from Somerford mini spares. I have succeded in getting the same effect with jubilee clips in the past. A quick rack will just have a different ratio reducing the total number of turns.
You are refering to the quick rack, not the bushes I suppose? I am delighted to read someone is happy with this setup.Personally I like them & have used them for years.
Posted 19 July 2012 - 02:36 PM
Posted 19 July 2012 - 03:30 PM
Posted 19 July 2012 - 03:42 PM
13 x 7 is significantly wose that a 10 x 5 for those.
Is your current steering rack in ood condition?
Posted 19 July 2012 - 04:09 PM
Posted 19 July 2012 - 09:53 PM
Posted 23 July 2012 - 07:02 PM
