Metro 4 Pots Under 10's
15 replies to this topic
#1 james.c94
james.c94
  • 164 posts
Posted 19 July 2012 - 11:29 AM
hi guys,
I've got myself some metro 4 pots brakes and want to turn the discs down, move the calliper mounting holes and grind the edge of the calliper to get them under 10's. I've had a good search and can't find much info on how or where I drill the new mounting holes and how much of the calliper I need to grind off. I'm aiming to fit them under 10 inch revos if that helps anyone.
Also before you all rush and tell me it's unsafe and stuff, I've had a good look into it before so have already thought about dangers and things. I'll be getting a machine shop to modify them for me and I'll get them crack tested before I use them too.
Also if anyone has a set of the callipers that have already been modified for sale then I might be interested in buying them.
cheers
james
Edited by james.c94, 19 July 2012 - 11:30 AM.
#2 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 19 July 2012 - 11:36 AM
hard to do with 4 pots as the centre bleed nipple gets in the way.
I've just put up a set of modded 2 pot's for sale though.
#3 Mini-Mad-Craig
Posted 19 July 2012 - 11:37 AM
I dont think the dangers outweigh the end product. Can't you space the wheels out to get more clearance? Or at least compromise and space the wheels out a few mm more meaning that's a few less mm you have to grind from the caliper. Either way 4 pots on a road Mini isn't really necessary at all, I doubt you'll even feel that much different from a decent 7.5" set up with good pads
#4 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 19 July 2012 - 11:43 AM
yup, i'd never fit metro 4 pots personally, too heavy and not needed imo.
#5 james.c94
james.c94
  • 164 posts
Posted 19 July 2012 - 11:47 AM
I don't really think the dangers are that great if the machining and modifying is done properly by an individual that is competent. The miglias ran modified metro 4 pot setups for years under 10 inch wheels before alloy callipers turned up. I've never heard any horror stories from that and they will definitely be testing the calliper to its limits and creating brake temperatures that are far higher than what I can achieve on the road.The main reason I want 4 pots is that I can have a much better braking system under 10 inch wheels and it will cost me a lot less than a cooper s setup.
#6 james.c94
james.c94
  • 164 posts
Posted 19 July 2012 - 11:49 AM
will these fit under 10 inch revo's?
#7 Mini-Mad-Craig
Posted 19 July 2012 - 11:51 AM
Fair play! Don't forget most Miglias are built with no expense spared, though. Good luck, keep us updated on your progress if you do ahead with it
#8 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 19 July 2012 - 11:53 AM
as far as i remember i've had original 10x6 revolutions and 10x6 starmags over them before, plenty of room on my 10" wellers
#9 james.c94
james.c94
  • 164 posts
Posted 19 July 2012 - 12:00 PM
ok mate, I'll let you know as I might get them for the moment whilst I get the 4 pots sorted.
#10 minimanjay
minimanjay
  • 230 posts
Posted 19 July 2012 - 12:01 PM
. I'm interested in your modded 8.4 what I'll it take to fit them to my car I already have 8.4 discs
#11 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 19 July 2012 - 12:06 PM
nothing, should be a straight swap
#12 minimanjay
minimanjay
  • 230 posts
Posted 19 July 2012 - 12:10 PM
. 07501084634 will you give me call pal or a text really interested ! Would pay pal you today if there wht I'm after
#13 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 19 July 2012 - 12:17 PM
will give you a shout when i'm home later as i'm in an office atm.
#14 james.c94
james.c94
  • 164 posts
Posted 19 July 2012 - 12:20 PM
They are built with no expense spared, however before all these alloy callipers started appearing the best brakes were metro 4 pots so they'd modify them to fit. This would of been back when metros were still fairly common too, so would of been more of a performance thing than a money thing. The migs try to save as much weight as possible too, surely if the 4 pots weren't worth the weight then they'd just have cooper s brakes instead?
Edited by james.c94, 19 July 2012 - 12:22 PM.
#15 minimanjay
minimanjay
  • 230 posts
Posted 19 July 2012 - 12:39 PM
. Ok cheers pal
