Clutch Bleeding
Posted 20 July 2012 - 07:54 PM
i have just replaced my clutch slave cylinder and am trying to bleed the clutch again but i can't find any pipe or hose to fit the nipple, can anyone tell me where i can get some and what size or whether i can buy and use a brake bleeding kit and this will fit the same size ?
hope you can help thank you
Posted 20 July 2012 - 09:10 PM
Posted 20 July 2012 - 09:21 PM
Posted 20 July 2012 - 09:56 PM
Posted 20 July 2012 - 10:36 PM
Posted 21 July 2012 - 07:37 PM
Posted 22 July 2012 - 01:42 AM
Posted 22 July 2012 - 12:44 PM
Posted 19 November 2013 - 11:13 PM
Posted 20 November 2013 - 12:17 AM
Fill the reservoir with fluid, fit a piece of pipe over the bleed nipple on the slave cylinder, unscrew the bleed nipple a turn, push the clutch pedal to the floor and hold it, tighten the nipple back up and slowly bring the pedal back up.
Make sure you keep the reservoir filled with fluid and just keep repeating the above process. You will most likely need to push the pedal all the way down about a dozen times before you see any fluid coming out. Keep repeating the process until the fluid coming out has no bubbles in it.
Its the old way of bleeding stuff but for me it always seams to work better than bleed kits. You will need two people to do it though.
