Front Subframe Mounts - Rubber V. Poly V. Solid?
5 replies to this topic
#1 zinzan
zinzan
  • Just Joined
  • 373 posts
  • Local Club: me and my imaginary friend
Posted 06 August 2012 - 05:54 PM
Will be tackling the replacement of the snapped front subbie on Red ('93 spi) shortly and will change out the mounts at the same time. Opinions on rubber mounts (as per original) vs. the replacement solid ones, please. I've not ordered yet.
Cheers, folks.
Solid:
http://minispares.co...|Back to search
Poly:
#2 Tupers
Tupers
  • 4,176 posts
Posted 06 August 2012 - 06:36 PM
Rubber will transmit less noise to the inside of the car but will rob you of feel from the front end especially under steering.
Solid will give you a better feel while turning but will make the inside if the car slightly louder.
In my opinion polly mounts have no place on the front subframe. Any subframe mount you can bend in half with two fingers shouldn't even be allowed on a car.
#3 Carlos W
Carlos W
  • 10,115 posts
Posted 06 August 2012 - 06:38 PM
If you're going to go solid adding extra strength to the toe board area would be a good idea!
#4 tiger99
tiger99
  • 8,584 posts
Posted 06 August 2012 - 06:44 PM
Yes, soild plus strengthening plates around the toeaboard mounts is best. The poly mounts which are currently available are very badly engineered and structurally unsatisfactory. Rubber mounts fail frequently, usually the toeboard mounts de-bond, although sometimes the metal fractures, and then the front of the car starts cracking up, often in the inner wings just ahead of the subframe towers.
Never mix different types of mount, or again there will be fatigue cracking.
#5 zinzan
zinzan
  • Just Joined
  • 373 posts
Posted 07 August 2012 - 02:01 AM
Thanks folks. Any suggestions as to how to go about strengthening that toe board?
#6 zinzan
zinzan
  • Just Joined
  • 373 posts
Posted 10 August 2012 - 03:59 AM
Ended up ordering solid mounts from Minispares.
