Chloe '99 Cooper - 1380Cc
#16
Posted 16 August 2012 - 01:49 PM
#17
Posted 16 August 2012 - 02:07 PM
One common sense conversation later and a fresh BFG. Now the exhaust on my car was a Peco full system which even with the new additional center box was still loud but passed every time so go figure. Plus it was running twin 45DCOE Webers and so on.
#18
Posted 16 August 2012 - 03:28 PM
This looks like a solid Mini! So this one has been converted from an mpi to a 1380 carb?
Indeed it has, which is great but there is so much extra wiring now that im mid process in sorting.
#19
Posted 16 August 2012 - 04:58 PM
#20
Posted 16 August 2012 - 05:05 PM
Isn't there a lot of wiring that's useless now? I mean, a carb engine has less electrical components than an mpi.
Yeah thats the job I left half done as I left for the UK, thers no ECU, different fuses and no injection gumpf. I found one loom connector about the size of my fist wedged under the gearbox linkage. So i'm re wiring now. Problem is that I have to strip all cables back as some are still used ie temp sender.
#21
Posted 16 August 2012 - 05:06 PM
#22
Posted 19 August 2012 - 09:45 AM
#23
Posted 20 August 2012 - 07:51 PM
-Headlining
-Brace Bars
-New Bottom Hose
-Reverse Flip Front Hinges http://www.superfast...d_hinge_kit.htm
#24
Posted 20 August 2012 - 09:49 PM
by the way did you go through the mot test? You can get hold of a decent MPI exhaust (with a cat) and it will pass both emissions and noise.
Now i dont know about mpi's but noise level should be 94db with a mini anyway..
Edited by jaydee, 20 August 2012 - 09:50 PM.
#25
Posted 20 August 2012 - 10:02 PM
Why did you get a 74°deg thermostat? You need 82° or 88° unless you have a very warm weather.. and 1" spacers are no joy for balljoints and wheel bearings..
German summer is pretty hot normally and she wont really be driven in the winter due to the snow. I was going to get a mpi exhaust but was told you cangt put a cat system on a carb car.
#26
Posted 21 August 2012 - 07:01 PM
I tell you because the 74° can make the engine run at a non optimal temperature for modern fuel, causing poor performance/mpg, you also have a front monted rad to aid cooling..
#27
Posted 21 August 2012 - 08:45 PM
#28
Posted 22 August 2012 - 10:31 AM
I get rid of it in the winter, and the cooler has got a 74° thermostat to avoid overcooling.
Mind you i have a sump guard fitted, with no sumpguard i dont think you need a cooler.
I'm not sure where you can put one in the mpi engine bay though.
#29
Posted 22 August 2012 - 11:03 AM
#30
Posted 22 August 2012 - 10:17 PM
I think you can retain the inner wing with the flip front.
This can be an idea:
http://www.theminifo...r/page__st__150
remove the big air scoop for the fresh air vents and reroute the coil bolting it to the cylinder head, and you'll have room for the oil cooler.
I can suggest also a vertical rad like those fitted to the early coopers:
http://www.somerford...page=page&id=93
Problem is that they're hard to get hold..they would fit great in that position though.
