Non Mini - Removing Locking Wheel Bolt (Without The Key)
Posted 17 August 2012 - 07:08 AM
I bought a BMW 3 series touring a couple fo months ago. I was going to inspect the rear discs, as it turns out the previous owner hasn't seen fit to include the locking wheel nut key.
I have tried knocking a socket over, and have even managed to spilt a couple. The problem is the heads of the bolts are almost round and have a couple of notches for the original key to grip onto.
I have bought a "locking wheel bolt remover kit" which is absolutely gash and it cost 35 quid. Basically a socket set with a reverse threaded inner, which cuts its own thread. Managed to remove one bolt with this kit and not the bolt is well and truly stuck in the tool. tried to get it out on a vice an breaker bar but the bolt ended up snapping. it was well and truly in-there.
I know you can weld a nut onto the end, i cant weld, I don't have much aspiration to pay someone else.
Any ideas?
Posted 17 August 2012 - 07:18 AM
Give the multi spline socket a go. Remember the nuts are very soft alloy so they could break. But that's not a problem if the head snaps off. Then you can remove the wheel & then use a punch to remove the rest of the bolt.
Posted 17 August 2012 - 08:43 AM
Posted 17 August 2012 - 08:55 AM
Posted 17 August 2012 - 09:33 AM
Are they nuts or studs? If they are studs you can drill a hole in they buy a left hand thread bolt (any decent fasteners place will have them in m6 and m8 at least) and wind it in, it will go so far then then stud will begin to come out. For an m8 you need a 7.6 or 7.8mm drill bit. I had this problem on a 944 and is was a major ball ache until I tried the above, then I had them all out in half an hour.
Had thought of that, but with an easyout, i though there would too much torque going through it though and it might spin or snap.
Lets just say the communication channels are exhausted with the previous owner after we found out he sold us the car with the wrong miles on the clock.
Posted 17 August 2012 - 01:53 PM
Easyouts are very brittle and very hard. If you do snap one you will be up the creek. They're also a lot more expensive. Another option is to use a Dremel to make a slot then use an impact driver. Good luck!
Posted 17 August 2012 - 02:14 PM
You can get them from screw fix for around £25 and they have become a valuable tool in my box.
If you are anywhere new Rochester swing by and I'll take them out for you.
Sorry for the brief reply, currently on my phone, I'll link the product once I get home.
Posted 17 August 2012 - 02:33 PM
how old is the car? could be worth trying bmw
Posted 17 August 2012 - 03:21 PM
http://www.endeavorp...tion/Id/18.html
http://www.youtube.c...bed/Ny4H27Cs7fI
Posted 17 August 2012 - 07:47 PM
Posted 17 August 2012 - 07:50 PM
Maybe this will work for you:
WOW! what an ad!
Unfortunately the heads where pretty round to begin with and are now totally round after me arsing around with the next size up remover socket.
Posted 17 August 2012 - 08:17 PM
A good chisel then takes no effort to spin the old nut off
If after that its still on i've taken to loosening the other wheel nuts, and driving until i feel a vibration.
Edited by charie t, 17 August 2012 - 08:18 PM.
Posted 17 August 2012 - 09:26 PM
get yourself one and you'll be surprised how many times you will end up using it. mine paid for itself within a couple of weeks.
Edited by ANON, 17 August 2012 - 09:27 PM.
Posted 18 August 2012 - 01:27 PM
Also too worthless tool back to the store for a full refund, happy days!
Posted 18 August 2012 - 02:42 PM
How did he do it?The guy literally had them both of in under a minute.
