Brake Failure... Sort Of
15 replies to this topic
#1 MRPAT150
MRPAT150
  • 10 posts
Posted 29 August 2012 - 10:12 PM
Hi i have a 77 clubman with a single line brake system just past a mot. For the past few weeks the brakes have been working fine on it but few days ago i was driving back and on my last corner the brakes suddently went on it now i have to pump up the system to get any force ive bled it checked for leaks but nothing can anyone shed some light on the situation as i am going to attempt driving to germany in it in a weeks time!
thanks dave
#2 Sam14
Sam14
    TMF Mug
  • 1,145 posts
Posted 29 August 2012 - 11:12 PM
Bleed nipple still left open a bit?
#3 MRPAT150
MRPAT150
  • 10 posts
Posted 29 August 2012 - 11:18 PM
nope they are all tight
#4 corrado vr6
corrado vr6
  • 286 posts
Posted 30 August 2012 - 06:18 AM
Seals in the master cylinder? Or if u have a servo maybe a failure there, but u never mentioned one so I'm guessing not
#5 coopdog
coopdog
  • 2,583 posts
Posted 30 August 2012 - 07:33 AM
wheel bearing is my bet!!!!1
jack it up and have a look :D
#6 jimnali
jimnali
  • 252 posts
Posted 30 August 2012 - 08:04 AM
It would help if you could better describe exactly what the problem is. Is it a) brakes do work but excessive travel on the pedal, b) pedal goes to the floor without operating brakes, or c) pedal feels normal but brakes are not effective?
As your car is a 77 model, it probably has drum brakes all round. Is that correct?
If you have not already done so, you should remove the brake drums and check for seized or leaking cylinders, and fluid on the brake shoes.
Before bleeding the system make sure that front and rear brakes are fully adjusted.
Good luck
#7 MRPAT150
MRPAT150
  • 10 posts
Posted 30 August 2012 - 08:32 AM
It has discs on the front the pedal returns its when you press down for the first time you get nothing you have to pump the system
#8 tractor
tractor
  • 514 posts
Posted 30 August 2012 - 10:51 AM
+1 i'd check here, you'll soon see if theres fluid leaking (and causing a loss in pressure) just pull the just cover back
#9 MRPAT150
MRPAT150
  • 10 posts
Posted 30 August 2012 - 09:11 PM
Would There be any leakage On the pedal at all
#10 valve bounce
valve bounce
  • 688 posts
Posted 30 August 2012 - 09:23 PM
master cylinder or leaking wheel cylinders is my guess, has the brake fluid level gone down?
#11 BlackJester
BlackJester
  • 114 posts
Posted 30 August 2012 - 09:42 PM
Take the rear drums off and if there is loads of brake fluid inside or when you pump brske fluid leaks out the cylinders gone. happened to me a few weeks ago. easy and cheap job to fix.
#12 MRPAT150
MRPAT150
  • 10 posts
Posted 31 August 2012 - 08:08 AM
I haven't noticed any fluid leaking
#13 BlackJester
BlackJester
  • 114 posts
Posted 31 August 2012 - 09:14 AM
No fluid leaking when you took the rear drum brakes off?
#14 MRPAT150
MRPAT150
  • 10 posts
Posted 31 August 2012 - 09:49 AM
Can't really check at the minute still at work
#15 MRPAT150
MRPAT150
  • 10 posts
Posted 31 August 2012 - 09:52 AM
But the most strangest thing is the brakes work in reverse but I get nothing when rolling forward
Mini Spares
