Wheels That Fit Zcar Mini
Posted 04 September 2012 - 10:16 PM
Still waiting for Zacrs responce. love a set of force racing wheels but that not an option at the min.
Posted 17 September 2012 - 09:51 PM
Posted 18 September 2012 - 12:51 PM
Ed
Posted 18 September 2012 - 12:53 PM
I have been told VW polo has the same PCD and off set, anyone confirm that.
They are not the same as a mini
David
Posted 18 September 2012 - 03:27 PM
I did notice that my studs aren't threaded all the way down so the nuts bottom out before the wheel is clamped to the disc. Do your wheels feel tight once they are done up? and do they look square to the mating face? pictures would be great if you had any too
Posted 18 September 2012 - 06:13 PM
Posted 19 September 2012 - 07:53 AM
Posted 20 September 2012 - 07:19 AM
I don't think I can add a spacer to remove this due to my arches and offset, so i'll be running longer nuts with the first few threads removed or changing the studs to some that are fully threaded. I don't get this problem if my alloys are fitted though as the mating face is lot thicker.
Posted 20 September 2012 - 10:16 PM
Posted 23 September 2012 - 09:59 PM
With a bit of look this should be some pictures of whats happening?
Posted 23 September 2012 - 10:03 PM
Posted 24 September 2012 - 11:31 AM
. CPTKIRK. THANKS i HAVE THE CHROME MINI LITE WHEEL NUTS. WHAT DIFFERANCE DOSE HIS MAKE WITHOUT SOUNDING RUDE!
No Worries, I should have explained myself a bit better. From what I can gather your nuts are not holding the wheel firmly against the hub. I figured that if you had studs that are a bit too long and were using closed nuts like these:
then you are only able to do up the nut until the stud hits in the inside of the nut.
If you were to use open ended nuts like these:
the nuts would never top out and you should theoretically get the wheel to sit firmly against the hub.
Is this a bit clearer now? if its not I can do a sketch to back up what I am saying.
I beleive that mini-lite nuts are slightly different to normal mini nuts (I thought the taper is slightly different) so if you were able to get some regular open ended mini nuts to make the wheel sit correctly then at least you would know its the nuts that are the problem and then you would have to try some deeper closed nuts - heres a link to some deep mini lite nuts: http://www.ebay.co.u...=item1c2a016e1f or just buy the deeper closed nuts and ignore what I was saying about the open nuts as it does exactly the same thing......
You may also have the issue that the inside diameter of the hole in the centre of the wheel is smaller than the outside diameter of the lip on the hub that the wheel normally sits on - is this also the case?
Edited by cptkirk, 24 September 2012 - 11:34 AM.
Posted 24 September 2012 - 12:35 PM
will try to post a picture up but as you know by now iam the the best on I.T. Cheers Lee
Lee, here's how to post pictures from your photobucket account:
In your photobucket account click on the direct link bit with the http in it and it will go blue, right click over it and choose copy:
then when relying in the forum click on the image button:
then a window will appear for a URL, just right click over the box and choose paste from the list and this will drop the link to your photobucket account into the forum, click OK - woo hoo - job done
Posted 25 September 2012 - 09:46 PM
