Respraying but someone used paint stripper :-(
Posted 22 March 2006 - 09:57 PM
http://gallery98629..../p27205171.html
Am I right? If so, how do I get round it bearing in mind I've got until sunday to get the car finished and its my only running car so I can't go anywhere to buy something (out in the sticks).
Thanks.
Posted 22 March 2006 - 10:04 PM
did it bubble like in the picture after you sanded and sprayed it?
if so it could need a wipe with white spirits or similar before spraying to remove any residue, grease etc.. from the bodywork.
Posted 22 March 2006 - 10:05 PM
It was cleaned with thinners and panel wipe too.
Posted 22 March 2006 - 10:16 PM
dave
Posted 23 March 2006 - 05:47 AM
Posted 23 March 2006 - 07:27 AM
A very light coat of Barcoat before you do anything else will stop any problems.
Posted 23 March 2006 - 10:01 AM
Posted 23 March 2006 - 06:26 PM
if it continues to react you may have to take all the paint off back to bare metal, then spray it with etch primer and topcoat. i had one where batteryacid had been spilled onto the paint and had to take it back to bare metal.
If he takes woodys advice and uses BARCOAT then the problem has been solved, the reaction will not appear again.
Posted 24 March 2006 - 03:13 PM
Thanks everyone.
Posted 25 March 2006 - 02:18 PM
Its not supposed to be like this is it? Does anyone have a close up photo of how primer should look after spraying?
Heres a photo of mine after some sanding.
http://gallery98629..../p27284668.html
Is it not thinned enough maybe? or is it something else?
Posted 25 March 2006 - 05:00 PM
The primer is taking for ever to sand down. It looks really uneven and pitted too.
looks far too thick to me. use more thinners.
Posted 25 March 2006 - 05:06 PM
If the BARCOAT hasn’t done the trick then you’re doing something wrong.
BARCOAT is used straight from the tin DO NOT THIN it down.
Once it’s fully dried around ½ an hour or so you can then primer over the top of it, DO NOT SAND the BARCOAT before you primer over it.
I can’t see a photo of what your primer looks like, but you should be mixing it to 4:1 ratio.
Posted 25 March 2006 - 05:59 PM
4:1 you say... The paint shop said 4 parts primer, 1 part activator and 10% thinners. Sounds like they might have it the wrong way about and should be 4 parts primer, 1 part thinners and 10% activator.
Just so I have this right, if I had a litre of primer, do I add 250ml of thinners and then 10% of the total amount or just 10% of the primer?
Posted 25 March 2006 - 08:36 PM
That photo is of the primer, not the barcoat and its the primer I'm having trouble instead with now.
The paint shop was right, 4:1 is 4 parts primer, 1 part activator and 10% thinners.
The 10% thinners is the overall measurement of primer and activator.
If you think that it’s to thick then just add more thinners.
Posted 28 March 2006 - 07:01 PM
the top layer dries before the underneath and when the underneath dries it pulls the top layer together causing it to wrinkle.
Just one other possiblity.
