any body have any piks of the coil and wiring to it on a 998? early starter type cheers.
998 Engine Piks
minimad82
, Sep 30 2012 04:13 PM
8 replies to this topic
Posted 30 September 2012 - 04:13 PM
Posted 30 September 2012 - 05:11 PM
why are you starting new topics for the same problem.
Pretty sure all you need to know is in the other topics
Posted 30 September 2012 - 05:20 PM
because it hasnt solved the problem, so eathier the wires are not original or the advise was wrong, so a pik would help a lot more
Posted 30 September 2012 - 07:02 PM
nothing wrong with the advice.
Only a few ways a coil can be wired
non ballast which I believe you said 1982 so it should be
white for coil positive
white/black coil negative
ballast which is 83 onwards
white/pink and white/yellow coil positive
a picture won't tell you anymore
http://www.theminifo...83-wiring-help/
Edited by lrostoke, 30 September 2012 - 07:04 PM.
Posted 30 September 2012 - 07:56 PM
tried it the way you have said and still get nothing, i no going to be a real simple fix just so frustrating, will post a pik up tommorow to show you, thanks for advise
Posted 30 September 2012 - 08:01 PM
Is there any voltage at the coil?
Edited by bmcecosse, 30 September 2012 - 08:02 PM.
Posted 30 September 2012 - 08:02 PM
how many wires come out of the dizzy appart from the HT leads on the cap
Posted 30 September 2012 - 08:06 PM
bmcecosse yes mate
irostoke there is one, that is already conncted, its the coil wires and the oil switch which giving me a headache lol
Posted 30 September 2012 - 08:15 PM
for photos you need to show the wire to the dizzy
coil wires
and wires to the solenoid..
basically show anything that looks like a wire
coil wires
