Which Sub?
#31
Posted 01 October 2012 - 07:45 PM
#32
#33
Posted 01 October 2012 - 07:51 PM
#34
Posted 01 October 2012 - 07:57 PM
Edited by megamini_jb, 01 October 2012 - 07:57 PM.
#35
Posted 01 October 2012 - 08:01 PM
#36
Posted 01 October 2012 - 08:06 PM
What would be best, ported or sealed? The enclosure will be under the false floor so will it make a difference if it was ported or sealed?
#37
Posted 01 October 2012 - 08:07 PM
Edit: spelling
Edited by megamini_jb, 01 October 2012 - 08:08 PM.
#38
Posted 01 October 2012 - 08:13 PM
It really depends on what you want your sub to do. At 300w you're not going to light the spl (sound pressure level) world alight so I'm guessing it's mostly for your own listening pleasure.
Sealed is easy, ported 'sounds' louder but you need to get the port right or it gets fuzzy. It's not rocket science and there's even calculators online to tell you how big to make it.
#39
Posted 01 October 2012 - 08:24 PM
Ported tunes (boosts) a speakers/enclosure to a targeted frequency but this will be at the expense at the rest of the frequency range.
Most of the off the shelf ported enclosures are tuned for volume at around 40 to 50hz.
This gives you a loud 'one note wonder' but not nice SQ.
You can build enclosures to boost at the hard to reach low frequencies (30hz and lower), this can help SQ (linearity of output). But is hard to do and easy to get wrong.
Go Sealed. Smaller boxes easy to build.
#40
Posted 01 October 2012 - 08:51 PM
Just looking on ebay and why do loads of people have a sub that's like twice as powerful as the amp. The other way round and you'd blow the sub, so surely having a powerful sub at like 1200w and the amp not even half that would sound ****
Edit: Oh, 1200w would be the subs maximum....
Edited by megamini_jb, 01 October 2012 - 09:00 PM.
#41
Posted 01 October 2012 - 09:01 PM
General marketting hype is to list the max power because people like big numbers.
#42
Posted 01 October 2012 - 09:06 PM
Yeah they are probably the boy racers selling their saxo's sound system and obviously the higher the watts to them iz lyk propa sick 4 tunez blud.Would these be subs that are being listed as "MAX POWER 1000w MEGA AWESOME BASS SOUNDS" and infact would probably go pop at a sniff of 300w
This made me laugh. Looks so stupid!
http://www.ebay.co.uk/itm/1000watt-Sound-System-Sub-6x9s-tweeters-And-Amp-/221130915549?pt=UK_Sound_Vision_Other&hash=item337c6dfedd#ht_500wt_1195
#43
Posted 01 October 2012 - 09:12 PM
I bet his boot catch really enjoys it.
*Edit* That "1000w" amp is actually 95w per channel, with a claimed bridge of 400w. I'd guestimate you'd be lucky to see 300w and then it would pretty rough.
Edited by Skortchio, 01 October 2012 - 09:18 PM.
#44
Posted 01 October 2012 - 09:23 PM
Its dual coil which means when wired in series its 4ohm and in parallel its 1ohm..
Take a look
http://mediacdn.shop....pdf?1317790168
I found this when looking at their 10'' series
#45
Posted 01 October 2012 - 09:27 PM
