Hi
Currently looking around for a new gearbox for my 1999 mpi which I believe has a 2.76 final drive. I have been looking at gearboxes with a 3.44 or 3.1 final drive. When changing to a different final drive would I need to change anything in the speedo drive to make it read more accurately?
The car has 13 inch wheels with 175/50/13 tyres
Changing Final Drive
BigRed07
, Oct 16 2012 11:16 AM
7 replies to this topic
Posted 16 October 2012 - 11:16 AM
Posted 16 October 2012 - 12:21 PM
You will need to change the worm and pinion in the gearbox, otherwise your speedo will be well out.
Posted 16 October 2012 - 12:25 PM
Thanks for that, is there a calculator I can use to work out the ratio of the worm and pinion?You will need to change the worm and pinion in the gearbox, otherwise your speedo will be well out.
Posted 16 October 2012 - 09:48 PM
Or change the wheels
Posted 16 October 2012 - 10:30 PM
Thanks for that, what is the standard ratio on my 2.76 final drive?
Posted 17 October 2012 - 06:22 PM
MPi's have a bespoke 7 tooth worm which drives a small 15 tooth pinion.
