How Can I Make The Throttle Response Less Aggressive Hayabusa
joss
, Dec 22 2012 03:50 PM
21 replies to this topic
Posted 22 December 2012 - 03:50 PM
Can anybody guide me to making the throttle response on my Hayabusa engined mini more progressive and less aggressive when pulling away
Posted 22 December 2012 - 03:53 PM
what setup have you got on it now?
Posted 22 December 2012 - 04:05 PM
zcar supplied a cable from the pedal to the throttle body. It is connected to the original throttle body cable plate.
Posted 22 December 2012 - 04:21 PM
there is nothing you can doing with the cable, but things like different length trumpets will make little differences, got a picture? its not gonna be cheap to modify the ecu, so things like slowing the airflow down will reduce pick time but also power unfortunately
Posted 22 December 2012 - 05:15 PM
how about changing the cable connection plate on the throttle body to a larger one or a snail shaped (helical) shape so that the throttle response is less aggressive to pedal movement?
Posted 22 December 2012 - 05:25 PM
it would still be the same ratio to your foot if im not wrong, so either way you put your foot down the throttle will still open at the same pace, tried not putting your foot straight down on the pedal ?? could upgrade the spring to a stiffer one to give a bit more force against your foot but then that shouldnt be the issue unless your foot is made of lead.
Posted 22 December 2012 - 06:01 PM
Thanks I will look into the spring upgrade and my leg is a prosthetic could be part of the problem have a happy xmas
Posted 22 December 2012 - 07:05 PM
could possibly be the problem, i stronger spring would still even be a good upgrade as you would get a bit better feeling where pedal is. your a very brave man driving a hayabusa engine'd mini with a prosthetic leg, i have a friend who races a 300bhp mgc who lost his left hand and has a contraption that looks like a ice cream scoop that clips to the gearstick. i absolutely shat myself when he took me round the track as an mgc really needs 2 hands on the wheel at all times and he's going flat out with one attached to a stick
Posted 22 December 2012 - 09:08 PM
Like anything else it takes practice
Posted 22 December 2012 - 09:12 PM
It would be an interesting electronics project but thought about a potentiometer on the throttle pedal and a servo on the engine end to open the throttle then a basic computor which will allow you to customise it to your personal preference?
Posted 22 December 2012 - 09:24 PM
a lot of work, expensive and not much room for failure
Posted 22 December 2012 - 09:27 PM
I wouldnt think it would be too hard really, a pot is only a variable resistor, so a simple system that if it sees X Volts, open servo Y degrees, with an arduino board that would be possible without too muchg knowledge in electronics
Posted 22 December 2012 - 10:24 PM
An electronic alternative using servos to control the engine revs may be a good idea I will research what cars have this system and see if they can be adapted
Posted 22 December 2012 - 10:41 PM
thats also another alternatvie, however with other cars most will be run through the ECU which would mean making your own controller anyway and more than likely end up being more expensive and difficult
Posted 24 December 2012 - 08:14 AM
This will definately work.
You will be able to make it so that the throttle moves less in relation to pedal movement intially and more to pedal mobement towards the end of the pedal travel.
